Big orange waste filter
I just bought my 2008 350 Rinker this year. I notice a smell when the toilet is flushed. Does the waste filter come factory standard for my boat or do I need to install a big orange filter?
  • YYZRCYYZRC Member Posts: 5,463 ✭✭✭✭✭
    My boat did not come with one. I added a Big Orange.
  • PickleRickPickleRick Member Posts: 4,371 ✭✭✭✭✭
    When you said big orange waste filter i thought you were talking about the Clemson University athletics department PR team.
    edited October 2020
    Big fan of Big Orange. Good stuff.
    https://bigorangefilter.com/
    Check your current venting. Might be plugged up with spiders.
    Some threads on here on building your own waste tank vent filter as well.
    One thing, was the smell outside or inside? If you noticed a smell inside when flushing then you may have a clogged vent line, or leaky waste line. If you noticed the smell outside then yes a vent filter is a good idea.
    I hear good things about Big Orange, but I've been making my own out of PVC pipe and aquarium carbon for years and they work awesome for $25. Easy to refill every couple of years for $7.
    Good luck
  • aero3113aero3113 Member Posts: 9,851 ✭✭✭✭✭
    There’s a chance that you might have a sealed filter already installed. If you do, you can easily cut it open and make a screw on end cap then fill it with new carbon whenever needed.
  • MiamiAGMiamiAG Member Posts: 210 ✭✭
    If you DIY, please use the carbon for air not the one for water.
  • mfritzmfritz Member Posts: 41
    Thanks for the comments, the smell is outside vent when you flush.
    What's the difference in aquarium charcoal and air? @MiamiAG
    Good luck
    Yaa, but Big Orange looks really cool!
  • Pat310Pat310 Member Posts: 605 ✭✭✭
    Wow @mattie that is some shine in that bilge. Impressive 😗
    The pore size. One is designed to filter air and has larger pore and pellet size. The other has smaller pores and smaller pellets to filter water.
    Mattie: it’s your nice clean bilge that looks cool, not the orange filter lol
    Miami: I’ve been using the aquarium charcoal for water filters for years and it takes the smell right out. I try to change every other year but the new owner of my 342 is now on 3 years with the same carbon and zero smell. Works fine, a lot of diy vent filters use the water carbon and all good.
    Three years with zero smell is amazing for any charcoal. You may be using carbon meant for air as it's cheaper and some of the inexpensive aquarium products use it instead of the more expensive stuff. Technically, it's not as efficient and should clog sooner.
    But, can't argue with three years.
    Maybe his $hit doesn't stink!
    Mellow yellow only YYZ   :D
    I agree, no 'finless browns' allowed on our boat.
    Lots of used BudLight goes thru - fo sho.
  • WillhoundWillhound Member Posts: 4,241 ✭✭✭✭✭
    Do none of you ever anchor out overnight or for a weekend? Or do you put a cork in it?
    LoL, you have to use the head for both! That’s what it’s for! Makes life much more comfortable!!
    After you install the big orange filter. Do you have to do anything before you do your waste pump out. I read somewhere that you have to be careful not to have suction in your waste tank when it is pumped out.
    The big orange has a built in vent/pressure relief so no worries.
    Thanks
