2005 270 Shower Sump
Bathbuoy
Member Posts: 15 ✭
Hi All
Just getting to know my 2005 270. Can I ask how the shower sump works. Is there a switch somewhere to operate the pump?
Thanks
Thanks
Rinker 270 instagram diary : sea_dream
There is also another bilge pump in the mid bilge outside of the plastic box to pump any other water out. That pump is probably wired into your bilge pump switch at the helm.
I don't think the shower bilge is tied into the switch as well but it may be that the bilge switch turns on all 3 if not 2.
Same thing with our shower pump when we first got our 2004 FV270....tried cleaning and nothing worked....it operated with the internal float switch...ended up purchasing a new unit and installing: Johnson 12V 1000 GPH Multi Port Shower Pump with Switch
