My 2006 Rinker 270 Fiesta VEE tilts to starboard side
Hi All,
Happy to join here.
I recently purchased a 2006 Rinker 270 Fiesta VEE - and have noticed that it tilts to starboard side. Both when sailing and in port. I would like to find the reason for this in order to correct it.
Any suggestions?
Thanks for the help,
Christian
  • J3ffJ3ff Member Posts: 4,224 ✭✭✭✭✭
    Fill the fresh water tank... mine does the same when it needs more water in the tank
  • LaReaLaRea Member, Moderator Posts: 8,061 mod
    Welcome to the Rinker forum!
    Weight balance is the key when not underway, but you're saying that she also lists to starboard at cruising speed?  Are you sure the trim tabs are both working correctly?
  • ChristianBjerringChristianBjerring Member Posts: 12
    Thanks for quick replies..!
    J3ff - thanks, I will definitely fill the fresh water tanks and see if it helps. Would be cheep solution to the problem...!
    LaRea - thanks, yes she both leans to starboard in port and at cruising speed. No, I am not sure if the trim tabs are working correctly. Just bought the boat a month ago. How do I check that?
    If it's too cold to swim (where are you?), use your arm or a boat hook to reach down to the tab on each side while somebody runs them up and down.  Make sure they both move the same amount.  Also, check the wake behind the boat at cruise speed.  It should be symmetric port to starboard.
  • Pat310Pat310 Member Posts: 603 ✭✭✭
    Be aware left switch operates right tab and right switch the left tab
    Thanks - it's a big help!
    ...and yes, a bit too cold to swim at this time of year here in Copenhagen, Denmark :-)
    my 2005 270 same problem it’s frustrating to have to carry all that water in the holding tank just to make boat level.
    You're right - but still I am happy if that solves the problem :-)
    I like it actually, tells me when it's time to put some more in!
  • Aqua_AuraAqua_Aura Member Posts: 2,702 ✭✭✭✭✭
    If it sat level with the tank empty then the complaint would be it's leaning with the tank full. Seems to me it would make more sense to have it level when it's full.
