My 2006 Rinker 270 Fiesta VEE tilts to starboard side
ChristianBjerring
Member Posts: 12 ✭
Hi All,
Happy to join here.
I recently purchased a 2006 Rinker 270 Fiesta VEE - and have noticed that it tilts to starboard side. Both when sailing and in port. I would like to find the reason for this in order to correct it.
Any suggestions?
Thanks for the help,
Christian
Happy to join here.
Any suggestions?
Christian
Weight balance is the key when not underway, but you're saying that she also lists to starboard at cruising speed? Are you sure the trim tabs are both working correctly?
J3ff - thanks, I will definitely fill the fresh water tanks and see if it helps. Would be cheep solution to the problem...!
LaRea - thanks, yes she both leans to starboard in port and at cruising speed. No, I am not sure if the trim tabs are working correctly. Just bought the boat a month ago. How do I check that?
...and yes, a bit too cold to swim at this time of year here in Copenhagen, Denmark :-)
