2005 270 Windscreen seals
Bathbuoy
Member Posts: 15 ✭
Hi
I have found a number of recent posts regarding 270 windscreens glass. Mine has dropped on the starboard side meaning I have a gap at the top. I have found from a previous post, the rubber seals available at:
https://www.taylormadeproducts.com/hardware/glazing-assembly-vinyls/
Will the part number of the windscreen I understand I need to find, be specific to my boat, or if the part is generic to all 270 windscreens, would anyone know what it is, or which seal would be the correct one?
Also does the same seal go the whole way around the glass?
many thanks
Paul
many thanks
Paul
Rinker 270 instagram diary : sea_dream
Although I may be thinking of a different window seal. I am referring to the screw cover seal but I guess you need the actual window seal around the window. I'll see if I can find that link and maybe they will have that as well.
I can not find that old post I have looked all over my previous post and don't see it.
From memory, I think the gasket is about an inch tall.
https://www.dkhardware.com/black-glazing-vinyl-9-32-channel-depth-1-4-to-19-64-metal-opening-100-roll-gc722blc-product-81314.html?gclid=Cj0KCQiAqdP9BRDVARIsAGSZ8Am9_eMsFeNgJtMDhd4jvKeU4HImr3kHh70cd82Oz4NTowCX3S6mAxoaAr2_EALw_wcB
