reverse polarity
Brought the boat home to do some tasks, plugged the shore power into my 110 using the same cords as used before and got reverse polarity, have not seen that in the last two months of plugging in...then nothing comes on. Did a little archives and google search and this does not sound good...
Black- I have a connector on my shore, my extension cord is three prong so it plugs in only one way and it's the same set up I have been using at the house so very confused as to what could have changed. I plug into a surge protector and then to the house. I had the boat at my storage place, plugged it in there but did not check the polarity there..could something have been damaged there and now have the problem? When I first plugged it in, the shore power light was on. When I hit the breaker for the battery charger(or any other breaker) it went to reverse and the generator light came on although the Gen breaker was off and I even have the master switch below turned off. I messed around with the chord,checking that I had power and when I looked again at the panel no lights were on on the panel. Will look at it all again this am but very puzzled!
rasbury,
Point of advice. Always turn everything off starting at your galley panel. Turn the individual items off first. Then turn the master switch off to shore power. Then the power to the cord, then disconnect the cord.
When plugging in shore power, everything should be turned off. Then turn on power at the plug, then the main switch, then individual items. Go in reverse order when turning everything off.
It scares me when you said your A/C ran briefly when you plugged in shore power which means it was turned on. That could cause Reverse Polarity.
So energize your power cord first, then energize your panel. Then energize each individual item. Reverse order when turning off.
Same thing when running the generator.
Turn off the individual switches, then the generator main power switch at panel, then turn your generator off. Reverse when turning on.
If I understand you correctly on how things are working (or improperly working) you turn on your AC main braker: no reverse polarity light, turn on another breaker and then the light comes on and your gen light comes on too? That sounds like a major issue: i.e. shorts/arcing in breakers/wiring. Maybe a picture (or series of) going step by step of what is lighting up would better explain this.
Does the breaker trip when the power goes out, or it just goes dark? No panel breakers or the breakers at the battery switches are tripping?
I'm betting on that surge protector being the problem. You would need a really big one to handle the power need potential of the boat. Most home ones are no where near rated for the amp draw. This could explain the power cut out too..it cannot handle it.
Dave
