My 280 was about $1200 usd for cockpit and swim deck.
That $40 a square foot probably accounts for the waste they will have. I can't remember the sheet size but they use most of it since they cut small pieces to fit the area and lay it out on a cnc machine.
LR have you looked in to Flexiteek? It has more of a wood grain to it. I have the old version of it but they have something new and much better but still as durable. Could be worth looking in to:
Just look at the difference though, you can't leave the platform naked. It does get pretty warm for the parts that have sun on them however when it's warm we are usually swimming anyway and the floor gets water on it or we can spray it with the wash down sprayer.
Can't beat the look of that faux teak ... by the way, you don't have a port side power plug in?
Aqua Aura - that does look a lot better. Agreed. I'm still on the fence as to whether I'd buck up & do permanent flooring again.....
I've started into a $5K stereo upgrade for this season. I tend to justify boat expenses one season at a time. (except for the balloon payment when I twofoot it upsize)
LaRea - I meant to tell you that if you are looking purely at durability - that PlasDeck is crazy tough. I used Starbrite deck cleaner on it all the time - no issues. The coloring runs all the way thru the product. Scuffs & cuts can be blended back in.
The EVA foam products wouldn't be as resilient, but they are more comfortable on the feet.
@LaRea I think carpet is a good way, most likely the the route we will go. @cotnerkc where did you get your carpet? a local place recommended these guys. https://corinthianmarine.com/
@06Rinker270 We ordered it from Snap-In carpet. They sent us a template and I checked the measurements. Sent it back and I think within two weeks we had our carpet. I borrowed a snap tool from a friend of mine. I like it because the water beads up. Carpet would absorb and would be wet all weekend. Not this material.
I have Aqutraction. I love it. The only problem was mice love it too. Over last winter when under shrink wrap, the mice made a home and chewed a section. Had that replace. Looks good as new
I'm always late to the party, but my MarineMat was ordered directly through Rinker, (They had all the templates). Probably nothing to see here that other manufactures can't or don't offer, but I will say this much....Mine is "snap-in" and not direct apply. So it is SUPER EASY to take out and clean it with a power washer and let dry in the sun. (not an option in a hard top boat) The backing on this is similar to the "white" backing on a good marine carpet. So I'm thinking it's not the same as the peel and stick they also offer. 3 years now and it still looks new !
https://www.flexiteek.com/
06 Rinker 270
06 Rinker 270
06 Rinker 270
Sorry @LaRea for hijacking your thread.
06 Rinker 270
