Charging circuit
What is the practical difference between an Automatic Charging Relay and a Battery Isolator. Are there advantages to one over the other. I understand that there is a more significant voltage drop across an isolator but not so much with the ACR. What else is there to think about when considering one vs the other..??? Thanx for the input.
I thought it sensed a charging situation when the batts were charging with either Shorepower or alternator, and allowed both batts to be charged but subsequently sensed when the batts were being discharged and isolated the Start batt to protect it....which ( if I understand you ) is exactly what the isolator does.
Thats why I thought the ACR was kind of "magic" if it did the same thing with no voltage drop. Youre telling me theres no such thing as 'magic"....??.... :-)
The other thing the ProIsoCharge does is prioritize the starter battery.
I can't think of a reason to use an ACR rather than a ProIsoCharge. The ACR costs a little less, but not a huge amount.
