2002 Rinker 342 Rocker Switch
There is a black rocker switch on the ignition helm panel to the very left of the keys? Anyone know what it's for? There is no lettering.
Now my problem is figuring out which wire(s) are for the ACC stereo - and possibly anything else?
A quick Google search and I can't find any wiring diagrams that look anything remotely like what I have.
The wire colors are:
Red
Black
Black/Yellow
Yellow/Red
Purple/White
Purple
Questions coming to mind -- Does the ACC typically do anything else other than the stereo? Should I worry about screwing something else up? Once I know which wire it is, can I snip just one and run it to the new ACC panel switch or do I need to do both - and can I run both to just one switch?
A few pics...
You could also use a test light poked into the wire insulation to see which wires get power when in ACC to help eliminate some options.
Red - Positive
Black - Ground/Negative
Black/Yellow - Off/Kill
Yellow/Red - Start
Purple/White - Trim/Acc
Purple - On/Ignition
So based on this, it would be the Purple/White wire - but I still don't know if anything else would be affected if I snip and switch it.
