can the water system be primed somehow?
rasbury
Member Posts: 8,270 ✭✭✭✭✭
I asked this before and had some suggestions but can't find the thread or in search....when I picked up the 270, the water system worked...I ran it dry and put more water in but can't seem to get it "primed". I have opened all the spigots and let it run but no water a following. I read some info it is "self priming" up to 10 ft. which made me wonder if it could be primed. It's hard to imagine something failed the same time it ran out of water...it may have run for some time empty but not sure...any ideas of where to start? Should I be able to pull a hose off and feel suction with my finger? Don't really care for the snap together fittings with seals that could dry out and leak....
Ras, the line that is coiled up and goes nowhere....for us northern guys, that is used to add pink stuff to the water system in the colder months.
The round thing, yes, it's a strainer/filter. yes, you can trying cracking it a bit to try to prime, even filling it with water may work.
