Lithium Batteries
WillhoundWillhound Member Posts: 4,238 ✭✭✭✭✭
I couldn't afford AGM, I can only imagine what these cost. 11 year warranty, I wish the cell phone companies took note. Of course, then they couldn't sell you a new phone every 3 or 4 years.
https://www.canadianyachting.ca/products/electrical/6102-total-battery-dakota-batteries
    They are a bit pricey although I think these are Canadian prices so maybe 20-30 percent less US price? About 3 time AGM for same AH however if they last that much longer then it does offset especially if you know you will keep your boat.
  • IanIan Member Posts: 3,043 ✭✭✭✭✭
    edited March 2021
    Add to that additional needs for runaway containment. Major mods in the B787 after a few incidents. And they don’t use these “cheap” types in a 787.
    This would be the last thing I’d like in my engine bay if I could afford them.
  • WillhoundWillhound Member Posts: 4,238 ✭✭✭✭✭
    That was my first thought, in the event of a leak, Lithium reacts with water to form hydrogen gas. Wonder of ABYC or any other organization has thoughts?
  • LaReaLaRea Member, Moderator Posts: 8,039 mod
    If they really do last five times longer than AGMs, the cost would make sense.  But I'll wait until we see a few years of fleet data in general recreational boating.
    We use Battle Born batteries in the RV/Solar field. Have held up well from all I have read
  • YYZRCYYZRC Member Posts: 5,381 ✭✭✭✭✭
    @Handymans342 off topic but where does one find light fixtures for RVs that aren’t hideous? I’m trying to find something halfway appealing to replace the fluorescent light in the head.
  • benvenuttiokibenvenuttioki Member Posts: 131 ✭✭
    on another forum, a poster commented that every potential insurer he had contacted asked whether his boat used Li-based batteries. It didn’t, so he was unsure how it might effect coverage. Posted for others to be aware.
  • MarkBMarkB Member Posts: 4,005 ✭✭✭✭✭
    Lead batteries make hydrogen when they are charged.  Let's not start castrating Li batteries on a blog ... death by social media.
    I think the bigger problem is the thermal runaway which I forgot about till the 787 comment. Although we transport 100s of lithium batteries each flight with all the laptops and phones we have on board and many of them are plugged in charging with no runaway yet.
    Agree. Was just more sort of wondering as I'm not up on Lithium batteries in this large format.
    Camping world.com
    The issue isn’t the hydrogen, its thermal runaway as I mentioned above. Once started it is self generating and propagating with extremely high temperatures. Like @aero3113 said they carry them on flights an there have been some issues and while one catching align on a flight is a bad thing and can be catastrophic in a rare case it is contained or limiting somewhat. You put a few large ones together without separation protection it’ll burn through the bottom of your hull before you know it. @MarkB it’s no fallacy - it’s real, just one non social media hyped p story https://www.scientificamerican.com/article/how-lithium-ion-batteries-grounded-the-dreamliner/
    I understand there are risks ... like with everything. Li batteries are taking over the world. 70% of the battery market is projected ... they are just better at almost everything. If the risk is known, then a risk-mitigation solution can be found ...
    Panbo has a good article about Ben Stein replacing his house bank with lithium iron phosphate batteries.  Ben feels that LiFePO4 is the safest of today's lithium chemistries.
    For his large motoryacht, the two house batteries cost $5700 ... EACH. The total system cost was $17k, and that's the DIY price!  So although it's not directly relevant to us little-boaters, it's an interesting read.
    As @MarkB said, lithium is taking over the battery world.
    https://panbo.com/upgrading-our-house-battery-system-part-2-life-is-better-with-lithium/
    Lithium makes sense for high power needs at a long rate...EV cars, power tools, etc.  In your standard boat just not worth the cost and trouble.  I looked at a 45’ Cantius with a massive battery bank and inverter to run a weekend without running the genny. Makes more sense for that...cost is just a deal breaker.
    Powerboat Television had a story this weekend on the Ranger R27 that mentioned that it came with a bank of 4 AGM's but could be upgraded to Lithium and an inverter to run the onboard air and heat without a Genny. Also a tug design that will run on plane up to almost 40mph with a 300 hp Yamaha for all you outboard haters.
  • oscar1oscar1 Member Posts: 803 ✭✭✭
    do you need to upgrade your  engine's alternator
    Generally you will need high voltage AC to recharge those big lithium battery banks. Unless you want to run your engine for days. lol.
    Lots of good and bad points.  A Li bank is smaller and lighter, and it charges faster so you don't need to run the genny as long.  And because it's an integrated system, you get better visibility about battery health and state of charge.
    But the system components (which are required) cost a lot, and most people don't need that sort of capacity.  I mean, suppose you could run the microwave and maybe even HVAC from batteries instead of the generator.  Sure, that's a nice luxury, but is it worth the cost?
    Also, Li batteries don't like heat, so I don't think you can put them in the engine room.
    To me, it's still a luxury item or special-purpose system.
    They don’t like cold either
    I don’t like thermal runaway and the means to contain it is not simple nor inexpensive.
    RV guys have done a lot of cool things with lithium and solar. Eat your heart out @LaRea
    Whoa is that the handy mobile? Quite a set up
    edited May 2021
    It could be one day Lib and we may need it with all the hacking going around
