Cleaning up trim tabs
Liberty44140
Member Posts: 4,318 ✭✭✭✭✭
Decided to clean up the trim tabs today. Soaked them for 10 min in 50/50 muratic acid and water. Then gave a good scrub with an abrasive pad, then soaked again for a few min, then another scrub and a good hose down and cloth dry. Worked great!
Worst part was removing all of the caulk (I think it was 5200 but I don’t know). Used a heat gun and scraper and 90% came off pretty easy, then used a wire wheel on a drill for 9% and finished the last 1% with acetone on a rag. Did that before the acid bath.
Next part of tab project is adding Bennett’s drop fins. Have to drill 8 holes in each tab. After 3 broken drill bits I have 1.5 holes Any tips for drilling through these stainless tabs?
added drop fins while doing this. Should have the same effect as adding 30% wider tabs. My tabs worked fine but I could tell I need some more to get the bow down farther while running.
