Rinda Techmate Pro
2»
  • Aqua_AuraAqua_Aura Posts: 2,705 ✭✭✭✭✭
    I did see your waste tank update 💩. Ours is definitely not that bad but we did just flush it out last week at the pump out. I wasn't aware of the tank saver product, sure makes it nice for spraying out.
  • aero3113aero3113 Posts: 9,815 ✭✭✭✭✭
    I might be going to look at a 2011 Chaparral 270 for my neighbor. Does anyone know if my scan tool with the adapters posted earlier will connect to a mercruiser 8.1 ?
  • davidbrooksdavidbrooks Posts: 1,431 ✭✭✭✭
    I'm not sure specifically. But I would recommend going on their website and downloading and flashing an update to the tool prior to heading out. It connects via a USB and the updates will do capabilities for newer engines.
    Thanks @davidbrooks , I’ll look into the update today.
    @davidbrooks , it looks like a special USB is needed to perform the update?
    Actually, it looks like you can do it with a normal USB cord. I just found these instructions.
    https://www.rinda.com/acro/TechMate_Pro_Update_Guide.pdf
    Rinda wants $159.00 for the update??
    Geez....so much for an inexpensive option of diagnostics.
    edited March 2021
    It’s really only needed to scan newer engines so it might not be needed. But still, charging that much for an update is crazy!
    You can get the ROM update that is a minor update for free.  The major one is the one that they charge for.  It is only for engines above a specific year so i havent paid for it.  It is nice to know that i can get it on my orignal device though and not need a whole new one.  Yes a regular USB cable works just fine.  I have done it myself.
    edited July 2021
    Has anyone ever checked or adjust base timing with the Rinda Scan tool?
