2000 270FV Power Trim Pump
I believe I have water in the reservoir of the pump that raises/lowers the lower unit. What are my next steps? I assume drain lower unit and refill the lower unit and the reservoir. Is that the correct thing to do first? Or, is there a way to troubleshoot prior to drain/refill? The boat is on a lift with the lower unit out of the water. Thank you for your help.
