How much water should be in boat after an hour?
thrcaptiva276
Member Posts: 12 ✭
I am brand new to being the boat owner on the water! I am the third owner of a beautiful Rinker 276 Captiva. She runs strong with a 496, everything works great, powers onto plane and everything. I properly placed in the drain plug. While I was learning the boat a bit, I was not throttling hard enough to jump on plane and the boat was stern down bow up for a little bit and we got water in the port holes from the engine compartment to the sitting area. Nothing the bilge pump couldn't handle. I ran the pump loaded the boat on the trailer and when i popped the plug it drained water on the ramp for a solid 2-3 minutes. Am I being over nervous?
I agree with @Dream_Inn , check the float for your bilge pump. With that much water in there the pump should’ve came on automatically.
Are you trimming your drive and tabs correctly? This will keep the bow down and get you on plane.
You should start out with trim down while getting on plane. If you have tabs you might just have to use them and not touch the drive much. Once you get on plane you want to slowly trim up until you feel the boat level out. It will take some for you to figure out the sweet spot.
It you stay trimmed down you are basically driving the nose of the boat into the water. Trimming up will raise the bow slightly so it starts to cut into the waves.
I had to deal with a boat leak.. where I learned that boat bilges should be DRY no matter what. If you have water down there, you have a problem.
I'd be worried about the amount you are describing!
The drain in the pic are the scuppers - one one each side toward the stern. Those are the one-way drains from the cockpit at the back of the floor near the engine compartment. There is a looped hose connection. Not likely the source of water.
Our boat was notoriously wet in the same area. Assume you have the Sport Arch - that added a lot of water intrusion. Canvas can't keep up with rain water running down the sides of the arch.
Yes those are both scupper drains on each side (4 in total)
They are designed to empty large volumes of water from the cockpit. The drain hose connecting them has an upward loop - so not to allow water in the boat. That won't be where water is coming into the boat.
Almost for sure the residual water will be from water flowing off the arch. Water tends to collect in the seat gutters & floor gutters and bilge.
One season I had water slowly coming in from a poorly installed Bravo III transom seal replacement.
Here's an old pic of our 276BR. Great boat - great times......enjoy.
