Broken walk through latch
goalie59goalie59 Member Posts: 326 ✭✭✭
One of my plastic walk through latches has broken. I was wondering if I should try to drill out the rivet and just put a self taping mounting screw . Kind of worried about breaking glass. Has anyone else done this. Thanks.
    There is not enough metal to use a self tapping screw. Plus never stay with the rotating part moving.  You can buy replacement latches then just rerivet.
    Agree with Black_Diamond
    YYZRCYYZRC Member Posts: 4,931 ✭✭✭✭✭
    It is very easy to disassemble the walk thru. Four Phillips screws. I would not risk drilling with the glass still in place. Agreed with above comments on riveting again.
    I have ordered Taylor windshield parts from Cecil Marine in the past.
    Aqua_AuraAqua_Aura Member Posts: 2,547 ✭✭✭✭✭
    If you take it apart be very careful with the edges of the glass. Tempered glass is extremely strong however the edges are weak and will shatter the whole thing.
    Great . Thanks for all the input. I am going to take a closer look at it this weekend.
