FV270 HOT WATER HEATER
skuter99
Member Posts: 174 ✭✭
Just curious how many of you actually use the hot water heater? I have had my 270 for 3 seasons no and other than to winterize it I have never used the hot water. Thinking of using that AC circuit for a cockpit fridge instead.
Would there be much downside to that idea?
I'd suggest leaving it in place, if you remove it you'll just have to figure out a way to re-route the hoses from the heat exchanger, and carefully re-route or configure the circuit so you can use it for the fridge but switch back, for example a new owner.
Better yet, if you don't have Air Conditioning you should have a blank circuit on your panel, why not just pop in a breaker and run a new circuit? By the time you re-route from water heater it's just about the same work and it'll allow to have both.
Looks like original 2004 location.
we use ours
I also do not have a 120v power outlet on deck
My 02 engine bay has looks like @Willhound
