Can you tell me what this line is for?
davidbrooks
Member Posts: 1,416 ✭✭✭✭
So i have been meaning to ask this question for a while. I see this line secured to the transom wall between my engines and i haven't been able to trace it fully to see what it is connected to. Anyone recognize it. Smart!@# answers are welcome but i really am curious what it is for.
Remove from the clamp holding to transom; route through plug hole.
Then start and warm the motor. (yes, on muffs)
Take fill cap off; remove filter.
This seems to vent the crankcase and thin the oil enough to drain quite quickly; I'd say no longer than 30-45 minutes.
Strange thing is no matter if you use this method or the extraction method, only takes 4-4.5 quarts to fill.
Hmmmm.....5qt. capacity the say.
MT was it one pump serving both motors, or two pumps?
AGREE! That pedestal for the remote oil filter is just ridiculous. Pretty much requires a large ziplock bag & a bunch of rags. I dread that part of the process.
Been discussed before but I think Ilmor Marine has a small containment tray around the remote filter. Best solution for a crappy design.
