Kohler 5 only run for 5 sec
jandavjandav Member Posts: 41 ✭✭
I have problem with the generator.
It starts but will only run for about 5 sec, then it shuts down with the error code UU (under voltage).
My tech guy has done lot of investigation.
Service kit is installed, spark plug, filter etc.
Fuel pressure is Ok.
The tech guy can get it running on start gas direct into the air filter....
Any suggestions?
