Trim Tab Switch - Repair or Replace?
prgrod01
Member Posts: 53 ✭✭
My Trim Tab switch on the Throttle controls seems to be slowly dying. up always works and the down procedure is press the button once, twice, maybe three times and hold your tongue just right and it catches.
I assume the switch is failing or the wiring or contacts is corroding and preventing a solid connection... regarless, has anyone changed one of these out? Doesn't seem like the switch was meant to be worked on, so does a guy just rewire it to a new toggle switch?
Thanks in advance
Thanks in advance
2001 Rinker 242
In this diagram, it's part # 6.
https://www.mercruiserparts.com/bam/subassembly/31819/12826/280
On my 2003 342, the brackets rusted like crazy. On my 2007 370, not at all. Not sure why.
