MarinAire Air Conditioner Install
aero3113aero3113 Member Posts: 9,323 ✭✭✭✭✭
I finally got around to installing my new ac unit. It didn’t go as straight forward as I was hoping. If there wasn’t a diverter that needed to be fitted to the blower it would’ve been a simple install. I had to rig the original diverter to fit with a run to Home Depot. It needs to be positioned like the old unit because the charging port is on the lower LH front. Any other position would put the port in a strange area. Since it was positioned this way, I had to lengthen some of the hoses. The gauges are also facing the correct way.I also relocated the control box to the area under the drop in bin under the fwd birth. @YYZRC sorry I forgot to do a sound test before I pulled the old unit out, but I can say it’s MUCH quieter. I think most of the noise is the blower running. Nice and cold now 🥶!!
