Anchor Wash Down
YYZRC
Member Posts: 5,366 ✭✭✭✭✭
It's time to tackle this. I anchor in muck frequently and thanks to Rinker's awesome anchor locker design (open vent to cabin), I need an elegant way to hose off the anchor and chain.
My proposed approach:
https://www.westmarine.com/WestAdvisor/Choosing-and-Installing-a-Washdown-System
- Planning to use sea water (since fresh water holding tank isn't big and often near empty after a 4 day anchor out).
- Contemplating adding a T fitting at the AC seacock as my water source. Even easier would be to add a T fitting at the AC unit since it's in the berth. Thoughts/comments?
- I will mount the pump in the anchor locker and add a quick-connect spigot in the anchor well. Pump recommendations that will provide enough pressure for a good spray?
- I will likely tap into the windlass to power the pump.
https://rinkerboats.vanillacommunities.com/discussion/10984/bow-anchor-wash-down
I didn't need it last year as I was anchoring in sand. This year is muck muck muck!!
What are your thoughts on adding a T in the AC water line just before the AC unit? That would make the install sooooooo easy!
I don't have issues running both. I also don't run the wash down non stop. Only for fish guts and spilt beer
Some people share the same thru hull with ac and toilet.
I like the idea of simply teeing off the AC supply line. I see there are questions here about whether this will work, but I’m certain it will as I often winterize my AC unit by back feeding antifreeze through the discharge hole on the side of the boat.
Hardest part was ripping the forward panels out to get access to mount the fitting. I was redoing them anyway (to remove the mirror) so the timing made sense.
There are a couple of pics here:
https://rinkerboats.vanillacommunities.com/discussion/comment/163030#Comment_163030
Here's the pump I used:
https://a.co/d/bx1orma
And here's the fitting:
https://a.co/d/hjtTMMx
I added an outlet in the transom locker as well so that I can wash the boat at anchor in shallow water.
