Winter storage
Looking at options this winter to store my boat.  Anyone in the Lake St. Clair verify options and prices ?  It's a 24 ft Rinker Captiva.
1) Store at my marina (Safe Harbor at Jefferson Beach).  Outside = $589.  Inside Cold = $1088.  Inside Heated (Not even thinking about too expensive).
What is the going rate for a company shrink wrapping a boat my size ?  I only ask because if it is close to the delta cost between outdoors and indoors ($500) then I would store inside without shrink wrap.
Does anyone else in the Lake St. Clair area store their boat anywhere else with better prices for either indoor or outdoor storage ?  I have a trailer so that's not an issue moving it.
Thanks.
  • J3ffJ3ff Member Posts: 4,245 ✭✭✭✭✭
    edited August 2021
    I used to pay 1900 a winter up north, including shrinkwrap. Now I pay 645 a month in the keys. Boating is dam expensive!!
  • PickleRickPickleRick Member Posts: 4,406 ✭✭✭✭✭
    J3ff said:
    I used to pay 1900 a winter up north, including shrinkwrap. Now I pay 645 a month in the keys. Boating is **** expensive!!
    Have you looked into buying a slip?
    No. Where can I do that? 🤣
  • mattiemattie Member Posts: 1,323 ✭✭✭✭
    Indoor cold……
    edited August 2021
    The slips in Charleston are dropping in price.  Im waiting for the ones in the middle keys to do the same.
    I've seen a few in the 110's but only allow a 50% yearly live aboard.  Fine for now but once my kid graduates I don't want to see winter again. I can go to Miami to play hockey.
    Indoor cold.  I pay 1500 for my 270.  I have access to it all winter.
    I pay $2k for indoor cold for my 39’. Indoor cold is half the price is heated. I plan to use the difference this year to have a high quality boat detailer compound and wax the entire exterior.
    @Liberty44140 - that's a good call.  My boats needs a good pro detail job too
    It’s $11/sq ft here for heated
  • JoeStangJoeStang Member Posts: 1,144 ✭✭✭✭
    I paid $240 to have my 276 cuddy shrink wrapped last fall, used a guy in the New Baltimore area.
    I'd say spring for the inside cold and do the winterization yourself, if you're comfortable with it.
    2013 276 Cuddy ~ 350 MAG / B3
  • kennydalglishkennydalglish Member Posts: 93 ✭✭
    Thanks for all the input.  Decided on inside cold storage and winterizing myself.
    Don’t forget to do your water system.
    Fresh water tank was pulled before I bought it.  What do you guys usually do for winterization ?
    Freshwater systems?  2 ways.
    1.  Fill freshwater tank with antifreeze and allow it to pump through all faucets until you see pink.
    Or - my preferred
    2.  Install a bypass on the freshwater tank and run a hose into a bottle of AF and pump through system.  Keeps AF out of tank this way.
    I store my boat in my pole barn which is not heated. One lesson I have learned is don't fill with too much fuel. The first year, I put it away after topping the fuel off on a 50ish degree day and in the spring, on the first 70 degree day I had several gallons of gas on my barn floor from the fuel expanding.
    Interesting that you charge per foot and not per square foot.
    $22 a foot is excellent, I am $46 this year, up from $42 although that has been the rate for the past 5 years.
    edited September 2021
    22/foot for winter would be nice, I pay 23/foot PER MONTH (7K+ per year) to keep it at the dock.
  • GMSLITHOGMSLITHO Member Posts: 1,626 ✭✭✭✭
    i love me love my barter deal
    I drain my fresh water tank as low as I can get it then connect the pump directly to my Campco jug and turn the pump on then go to each faucet and turn them on one at a time until I see pink out of each one
