Transducer Install
YYZRC
Member Posts: 5,509 ✭✭✭✭✭
I want to install an active imaging transducer on the trim tab. I know this isn’t recommended but I don’t want to drill the transom and I’m wondering if anyone has done this? I realize it won’t work on plane but I don’t need it then anyway.
The style of transducer seems ideal for flush mounting on the tab.
This is what I bought
https://www.amazon.com/dp/B079DWDDWC/ref=cm_sw_r_cp_apa_glt_fabc_SDTP7JQ9DDWAF3645VAQ?_encoding=UTF8&psc=1
I do plan to put one screw in the middle and I will put some sealant on the backside of the starboard where the screw pokes thru them stick it to the transom and screw it on.
The transducer has a hinge that flips up to save the transducer if you hit something. When you lower the trim tab at cruise speed, you'll have water hitting the transducer at an angle. The force will probably flip the hinge, and then you'll have to swim to reset it.
As @Aqua_Aura said, the trim tab is angled with the hull's deadrise, so your transducer won't be pointed down unless you install a wedge to level it.
Also, the transducer might overheat if it's out of the water when the trim tab is up.
To drill in to the transom just make sure to over drill the hole and epoxy the hole. Then come back and do as stated above in using a good sealant, I use 4200 and not 5200. The epoxy "washer" is key to ensuring that your transom stays solid as you will be screwing in to epoxy, not wood. I used West System Six10 to re do my tabs and underwater lights last spring and it was awesome!
I drill those holes out to about 3/8 and slightly deeper than my mounting screw.
I clean the hole out with acetone and q tip.
I mix up some epoxy resin, dab a little with the q tip to wet the core and fiberglass.
I add thickener to the resin until its about like toothpaste.
I then take a syringe about the size of what you'd use to season a turkey and push the resin in the hull until full. I then wipe the surface of the hull flat with a putty knife.
I clean any excess resin up with acetone and clean rag
I put some painters tape over the holes to dry for 24 to 48hrs depending on temps.
I redrill my pilot holes, carefully thay i don't go past my epoxy insert.
Finally install your transducer with 4200 (you know you're going to upgrade later )
If the 4200 ever fails you won't get any water in your core as epoxy resin absorbs less moisture than your vineylester gel coat.
Any time I've cut open a transom the water has come from trim tabs or transducers or anything going thru the hull below the water line.
I also like the starboard mount but if you use a screw to hold it while the glue sits id use the same method.
The transducers I've purchased usually come with screws around @3/4 inch, they go in well past the fiberglass hull and into the wood core.
My bottom hull wasn't thick enough at the bottom to fit all the transducer mounts into the bottom solid fiberglass.
2015 Scarab 165G
Laser Sailboat
2002 Seadoo Explorer
2023 Seadoo Spark Trixx x 2
https://www.bluesea.com/products/category/23/Cable_Clams
Are you sure it's 3/4" you need to drill, seems excessive. I think mine is less than a 1/2"
2015 Scarab 165G
Laser Sailboat
