Changing Steering Cable on 240
Stever00
Member Posts: 145 ✭
I already ask how to order new steering cable. All the numbers are worn off cable at transom. Today I got cable loose from motor. Removed gage cluster and vhf radio to get to steering rack. Rinker did not leave any room to get 7/16 wrench on the four bolts. Had to hold bottom threads with needle nose ViseGrips. To get nuts off. One bolt would not even pull out top it was so close.
This has got to be one of most difficult things I ever tried to do mechanically. I see why many boat mechanics dont want to do them.
My question is why will rack not come off steering column with 4 bolts out? I've pecked it with brass bar, wiggled it. It wont budge. Such a tight area hard to tell what's going on.
To get cable pulled out to front had to take all access panels off that side. Rinker zipped tied cable in several places. You have to watch for that. The last turn at steering wheel you have to reach in and guide long steel part of cable around the corner.
Teleflex number will be near the rack on mine not at stern. It is SSC12475 Teleflex USA 7050. That's confusing because last two digits suppose to be length. I have 13 feet of insulated (black) cable. Teleflex says measure that and add 30 and round up to next foot. That would make mine 15.5 feet not rounded up.
I will give you and example in photos below.
The sketch is of my rack.
