Won’t start-SFCO CC1
Spyderweb
Member Posts: 963 ✭✭✭
Genny wouldn’t start last week. Found fuse 6 on controller blown. Replaced fuse this morning and still won’t start. It gives a click and shows code above. Checked all fuses and they are good. All seem to fit snug well plugged into controller.
I run it 30-45 minutes each week to “exercise” it. My home marina and my winterization/storage marina don’t do gennys. Any ideas?
I would attempt to check and clean connections and look for loose wires.
How easy is it to get behind there?
You can search Google for the manuals, the forum won't allow me to upload pdf files for some reason.
@LaRea fuses all seem to fit tightly. With each fuse out I carefully poked each metal bracket and each seemed intact, no slop.
Anyone know what’s involved to get to the back of the controller?
Another problem I had was bad ground going thru the feed thru at bottom of genny. Actually, it was corroded ground wire that was on back inside.
Should charger starter battery cable be unplugged before messing around back there?
Oh well, it’s only money.
The regulator is digital so it may be in the controller and this may be the reason it blew the fuse and your getting a code to replace the controller.
Maybe look into the voltage regulator side of things and see if you get anywhere.
After unanswered texts and phone call I had given up on mechanic showing up. Then, this past Thursday, a day I planned to go up to boat to begin end of year stuff, get message mechanic has another job within 35 miles of me and will come to boat if I want.
When I get to boat he had just arrived. After about 5 hours, much studying of Kohler literature, many phone calls to the home office, he's successful. The biggest time killer was trying to get power to controller. while playing with back of controller, specifically the auto/run switch, the panel suddenly lights up. He says switch (though working at the moment) should be replaced.
A short time later he notices some corrosion on one of the house battery terminals (+). When he touches the cable, he notices that it's loose. He tightens it up and generator starts up. WHAT? A loose house battery cable?
Now I had removed, cleaned and re-installed the cables to the battery that sits right behind the generator with no success in fixing problem.
1. Help me understand what a house battery on the opposite side of the boat has to do with the genny. Everything else on the boat works.
2. Replacing switch is a simple fix. Remove controller (I've done that), then the 3 wires in the back of switch, reattach 3 wires to new switch, re-install controller. Problem is, can't find switch. I have a very detailed parts list for generator (posted on this site previously), but there is no part listed for stand alone switch. Any ideas?
