Air condition raw water bleed off valve PVC & Brass !
oscar1
Member Posts: 804 ✭✭✭
I am doing a bleed off valve for my a/c raw water side, but i am wonder if i should use PVC schedule 80 or Brass fittings for the installation of the design. It is going to be under the water line. So a
ny ideas will be appreciated like always. thx
My only problem with PVC ball valves is they can be really stiff to turn sometimes. I have a bleed off and it's bronze I think. Same as a seacock bit the valve is smooth
I don't know thay there is a best, unlike sanitation hoses where you can you can judge the quality with your nose.
Fwiw I also have the plastic bleeder valve. I don't mind it being pvc as the thru hull is brass. If l left open in a slip all the time like in sunny Miami, I can see upgrading to brass being a no brainer.
https://www.ebay.com/itm/MPI-series-100-HARDWALL-3-4-ID-MARINE-WATER-HOSE-Wire-Reinforced-by-the-Foot/322511049971?item=322511049971&pageci=0fd3933d-e972-493a-86e8-b6f5be169bb6&epid=2087004519
