Hello
2»
    Visiting the Netherlands is on my bucket list. Welcome.
  • Peter13Peter13 Member Posts: 96 ✭✭
    edited November 2021
    Hello davidbrooks , thank you and have fun in the Netherlands if you go there
    Best Regards from Cologne send´s Peter .
    I have a Question to Generator´s .
    Wich Generator can you recommend ?
    Does anyone know this  Champion Mightyatom 2500 Inverter Power Generator ?
    I have 3 shortlisted so far : Champion / Denqbar / Honda .
    The Generator should possible also be used at Home if necessary .
    What have you good experiences ?
    Thank´s !
    Honda
  • YYZRCYYZRC Member Posts: 5,500 ✭✭✭✭✭
    Yep, Honda.  It will be reliable and will not depreciate.
  • aero3113aero3113 Member Posts: 9,964 ✭✭✭✭✭
    I agree, and the Honda’s are much lighter.
    Honda
  • Dream_InnDream_Inn Member, Moderator Posts: 7,954 mod
    Yep, if no concerns on cost, definitely Honda.
    Not sure they will run air conditioner if that’s what you want it for
    Thank you all for the Opinion !
    @Pat310: Yes , that would be nice if the Generator would work . That's why I came up with the Champion Generator with 1900 watts of continuous output. But if he couldn't create the climate either, then I'd rather go for Honda.
    I believe it is the start up that is the problem. I remember someone on this site talking about a soft start mechanism that can be installed on the air conditioner to allow it to run on the small generator
  • IanIan Member Posts: 3,069 ✭✭✭✭✭
    I have a ryobi 2200 and it ran the AC without issue, key is disable the auto idle.
    Thank You all ,
    okay , this Soft or Smartstart are Option for Climawork .
    …. and the next question….  :#
    for the Frame of the Windshield there are these clamps for the snap fastendes . My Dealer says there are 2 different ones ( short and long).
    Does anyone now wich are the Rinkers in our Frame ?
    Thanks !!
    Taylormade Taylor N A 407 .
    The 407’s are the ones I used. I would think they’re the short ones.
    Super aero3113 , Thank you !
    I meen also the Short Ones for the Rinker Frame.
    My old Sea Ray Boat has a bigger Windshieldframe and i think this must the large Version .
    So question about installation...I will be re installing my carpet, carpet snaps are installed. How do I transfer to the floor to put those snaps in the right spot?
    i would do this with water soluble paint.
    this is especially difficult for me to explain with the translator.
    but the google translator is far better than my english from school 45 years ago
    This Paint , its here for Kids etc
    would it be an option to transfer the carpet onto a piece of cardboard paper or foil as a stencil?
    then you could make the places of the push buttons with a pen / Edding
    You mean new caret with snaps in already? And they don’t align with the male parts already?
    You don’t need paint. Just use your thumb or your foot to push the carpet down onto the snap. Then pull the carpet up quickly, and you will see a small dent in the rubber backing where the snap was.
    We installed new cockpit Berber carpets this summer and it came with the snaps loose. Decided to lay it without installing them and found they stay in place, also easier to remove for cleaning the deck.
    Agreed with @Grahamu. I don’t understand why people install 100 snaps when 6 will more than suffice.
    Yes Grahamu , that´s good so .
    We also renewed our carpet and opted for the Velor Teak design. I also wanted to transfer the existing press studs first. But I didn't do this because the carpet holds up so well. The only thing would be the small thin strip to the door on the bathing platform. We just don't have that piece of carpet. It actually works very well with no snaps.
    hello aero3113,
    I have to ask again about the snaps.
    Someone said that these Taylormade buttons were only available in one size and would not fit in the context of a Sea Ray.
    Do you know if the frame of a rinker has a deeper groove?
    They fit fine on my windshield (2008 330). In this pic, you can see that the plastic insert is all the way in the groove (I didn’t have the screw all the way in yet). Also the groove looks much deeper than the Sea Ray pics you posted.
    Yes, you are absolutely right . Thanks for the pictures and info
    edited December 2021
    They patterned the new carpet from the old and put the snaps in best they could- can't imagine they will align . So I can't impression the carpet backing and doing this in reverse.  They only had the carpet and not the boat..
