Winter Projects
davidbrooks
Member Posts: 1,432 ✭✭✭✭
What winter projects is everyone working on this winter? Boat or non boat related. I am replacing my canvas so that is going to soak up all my boat money. I have a local company that is going to do a full custom enclosure. Higher end materials and strataglass. I replaced the negative block on the transom. That was long overdue. Of the 12 wires going in 4 of the terminals came off in my hand. I am also going to get my Fireboy Extinguisher inspected and refilled. That is long overdue also. I finally found a local guy to do it and for a reasonable price. Other wise i am stuck in the house till spring. What do you all have in mind?
On grounding blocks, the real issue is the low-quality crimp terminals that allow moisture into the connection. The best solution is to cut off an inch or two of wire (until you see bright copper) and terminate with a new heat-shrink terminal.
The other problem is Rinker's practice of jamming two, three, sometimes four wires into a single ring terminal. You can't keep moisture out of the terminal if there are multiple wires going in. It's better to have multiple terminals stacked on the screw (but no more than four on each screw).
https://www.amazon.com/Stripper-Electrical-Klein-Tools-11063W/dp/B00BC39YFQ
• Disassemble windlass & clean & grease. (never done it before)
• Find the slow parasitic drain on the house batt.
2. Bottom paint
3. Throttle and steering cables etc adjustments
4. Fir new steering wheel
5. New blower hoses and vent covers
Then usual spring activities!
https://www.hardin-marine.com/p-14399-13-34-isotta-carlotta-steering-wheel.aspx
