REMOVING SOUND SHIELD TO CLEAN FLAME ARRESTOR/ REPLACING SPARK ON NON SERVICE SIDE
SERENDIPITYSERENDIPITY Member Posts: 83 ✭✭
How do i go about it? screws located?  do i remove  one panel at a time and all panels have to be removed ? tks
    Remove the service panel.
    Remove the top 2 screws on the LH side of the top panel.
    Remove the 2 screws from the top of the side panel.
    The side panel will tilt out to remove.
    If you take out the screw from the front right of the top panel, the top/back panel will tilt back too.
    The screws are finicky to get back in lined up right, just take your time.
  • SERENDIPITYSERENDIPITY Member Posts: 83 ✭✭
    TKS AGAIN  BLACK_DIAMOND
    No problem. I think I know too much about the 5e. 8-}
    WELL on the weekend i got the front,left side of the sound barrier off.all the screws are out and the right side.and top side  .cant get them to release .do i punch in the side wall or out?
    Tilt the top/back cover backwards. The side panel has posts to locate it to the bottom. Should tilt out and pull up.
