REMOVING SOUND SHIELD TO CLEAN FLAME ARRESTOR/ REPLACING SPARK ON NON SERVICE SIDE
How do i go about it? screws located? do i remove one panel at a time and all panels have to be removed ? tks
Remove the top 2 screws on the LH side of the top panel.
Remove the 2 screws from the top of the side panel.
The side panel will tilt out to remove.
If you take out the screw from the front right of the top panel, the top/back panel will tilt back too.
The screws are finicky to get back in lined up right, just take your time.
