Mobile Vessel View
rasburyrasbury Member Posts: 8,907 ✭✭✭✭✭
I was looking on line and I can get the mobile version for 195 bucks...how do I know if my 2005 will work? It says 2004 and up but....
  • Pat310Pat310 Member Posts: 602 ✭✭✭
    @rasbury 2005 should definitely be smart craft compatible. If you have the original flame arrest or cover it should be marked with smart craft label.
  • WillhoundWillhound Member Posts: 4,240 ✭✭✭✭✭
    And (I believe) if you go to the Mercruiser parts website and punch in your engine serial number it'll confirm if compatible.
  • rasburyrasbury Member Posts: 8,907 ✭✭✭✭✭
    edited March 2022
    Sweet, thanks guys. I don't recall seeing that on the cover...boat is 05 but that does not mean the engine is and I think 04 is the cutoff....so this will pull engine codes too correct?
  • raybo3raybo3 Administrator Posts: 5,608 admin
    I believe its 2002 and up. You will be fine @rasbury
    Yep.  Mine is a late model 2002 and it works
  • IanIan Member Posts: 3,053 ✭✭✭✭✭
    Mine is 2002, engines 2002 and have SC. Look on top towards the stren port side near the relays for the plug.
    There are a couple of plugs there (I think 2) and assume that is where you would hook up diagnostics computers to...which I guess what vessel view really is....i will probably spring for it.
  • GrahamuGrahamu Member Posts: 919 ✭✭✭
    This is the plug you need to find, it's at the right rear of engine. Depending on where you mount the module you will need extension cables.
    edited March 2022
    Yep, that looks familiar.  But now it's starting to sound like work. So it is powered through the plug right? And where the heck on the extension?
  • Cableguy GregCableguy Greg Member Posts: 5,075 ✭✭✭✭✭
    The hardest part was mounting the unit. I ended up Ty wrapping it to the harness on the back of the engine room. It is plug and play.
    Are you single engine? I think there are posts on the cables needed. I'm dual and the set up is different. You might be able to plug in the module to that plug if you want to keep it in the engine compartment.
    edited March 2022
    @rasbury - This is a super easy install...don't be intimidated.  No extension cables needed..just the VVM device.  The one additional thing you will need is the yellow terminator plug.  That's it.  Plug it all in and done.  I found a place on top of the engine to zip tie the VVM module.
    New Mercury Mercruiser Quicksilver Oem Part # 859318B 1 Terminator https://www.amazon.com/dp/B00N6DHO5M/ref=cm_sw_r_apan_glt_i_PA7N3TG7EP1S3VJDH5XQ
  • GMSLITHOGMSLITHO Member Posts: 1,602 ✭✭✭✭
    I put this on my 270 yep really easy and it worked great the one thing I didn't like every time I shut the motor off then restarted it I had to reconnect to the VV to  bluetooth every time, now that you have the hatch fixed get the VV for the dash and get rid of all the guages
    Thanks as always rinker crew- have been at the marina for almost 3 months..no trips- took tomorrow off and weather is awesome!
  • SpyderwebSpyderweb Member Posts: 955 ✭✭✭
    Single engine is very simple, plug and play.  Twins is trickier and $ with more cables and junction box.  Download free app to phone or iPad to view.  Mine never has problem hooking up through blue tooth when engine turned on.   And module is located in ER, iPad at helm.
