AC hose
Dream_Inn
Member, Moderator Posts: 7,552 mod
So, I believe it figured out why I have some water in my mid bilge area. I have a little drip after the ac pump where it Ts off to 2 lines, one for each ac unit.
So, while I'm in there I plan to replace the input line to the pump from the seacock. Anyone know the size? Is it 1 in ID? Here is a pic I took.
My 342 and my current CY 390 both use the same 3/4” Id intake hose for the AC. Hardwall.
https://www.ebay.com/itm/322511049971
Yesterday, my AC pump would not prime after I cleaned the strainer. I unbolted the pump and held it down lower than the strainer, and it primed immediately. I reinstalled it in the original location, but I should have just remounted it lower.
I completely agree, & so does mine. But I keep my boat on a lift. So, when I put it up after each weekend, I close the AC seacock. This allows me to turn on the AC/heat when I get down to the boat without either having to go for a ride or loosen two screws around the pump for prime. It is possible that it could self prime too, but I'd rather be cautious since I do it every weekend. Not a huge deal if I forget as it is very easy access under an access door in the salon.
@earl1z19 Is the valve located between the seacock and the pump? I had thought about adding one there for winterization but just pull hose off of seacock & insert funnel into the hose. Pretty easy, but maybe I could just add this bypass in and use it for two things. Do you have a pic of it? or know which you used?
Ray
2006 390
Previous 2000 340
I got rid of the white splitter thing and did something that looked a little better and safer looking Also my boat needed a new pump. For priming I just take the boat for a spin pushes water through the system. I will see if I have a picture of my setup.
2015 Scarab 165G
Laser Sailboat
2002 Seadoo Explorer
2023 Seadoo Spark Trixx x 2
