Low Profile Bilge Pump
aero3113
Member Posts: 9,563 ✭✭✭✭✭
Anyone ever see this bilge pump? I’m thinking about installing it at the lowest point in the bilge at the drain plug. The original will be a backup if this one ever fails. I can use a “Y” adapter and plumb it into the existing hose. Thoughts?
https://www.whalepumps.com/marine/product.aspx?Category_ID=&Product_ID=10002&FriendlyID=Supersub-Smart-Low-Profile-Automatic-Bilge-Pumps
”Y” adapter
https://www.go2marine.com/Rule-Pump-Adapters?gclid=Cj0KCQjwma6TBhDIARIsAOKuANwD2zzLVU2Mo7kpqkj8fvCGDidWZt203x3YEqrGNGw4CjXQ5q0_HMwaAoBzEALw_wcB
”Y” adapter
Pump
Adapter
https://a.co/d/eeV6dc3
System Three QuikFair Epoxy Fairing Putty
I've never had multiple pumps before, but that's how my current boat is wired. Each bilge has two pumps -- one on the house bank and one on the port starter.
I filled the bilge with water and bilge cleaner last night. I wanted to see how high the water goes with the stock bilge pump. The water can go all the way to the top of where the garboard plug opening is, that’s pretty high and I would say well over 5 gallon, maybe close to 10. I plugged in the low profile pump and there maybe a half gallon left behind. First and second pic is with the stock pump, third is with the low profile pump being used. I’m not too happy yet with the bilge cleaner. It looks like it loosened up some grease but it also left it behind on the transom and bulkheads. Maybe I’ll have to do it a couple of times to get her cleaned up. Also, maybe make a run with the cleaner to let it slosh around.
