Just put the 2002 fiesta vee 270 in the water from marina over winter service..leak!!! Help!please..
maxwell
Member Posts: 106 ✭
Hey guys..what a nightmare weekend...after launching her and docking ..i notice the bilge going on and off,,definate leak..but can not find out from where!
is it possible the 2 through hull water intake pipes(Toilet and Ac) are leaking water in?sealant around them is not great looking.
but...yes ,back plug is in...all freeze plugs ..on engine... 4 of them seem tight...good amount of water coming in..i put it back on the trailer..quickly...can not tell...where..its coming from??was good all last season...boat was not running ..and docked.. but...water kept coming in???checked small bellow casing...(the leaker some say)..looked intact..although the big one had a big split..but other boaters said thats not a probem..its an exhaust ..is that right?
i am pretty sick about this..any suggestions??thanks.
could it be coming in from the torn exhaust bellow?
I replaced the chaulking on the 2 through hull water intakes with expoxy..then more 3m marine sealant,,have to let it cure..wont be back up until thursday..fingers crossed...
the maddening thing about this..is that it floated in marina no problems all last summer..now this...
Fill the bilge on land enough to cover the thru hulls to see if water comes out the thru hulls. If it a very minor leak they may not drip since there isn't much pressure pushing thru them as opposed to the weight of the boat displacing water when floating.
If you still have trouble finding it then back it in the water on the trailer with the hatch open and have someone looking for leaks. The drive line bellow should be easy to spot a leak as you will see or hear it dripping in from the inside.
If the thru hulls are leaking they need to be properly re-bedded you can't just put sealant around them and expect a good result.
When boat was out of the water ..there was water all around the new float switch,in the bilge and it was not leaking out of the boat from bottom..is it possible that with the boat .."IN' the water..the pressure would force it leak from that screw whole..?
also ran chalk around the whole i/o fixture where it connects to the transom..even though, it looked tight..for whatever that was worth..
the ones I found were screwed closed,but one was not really tight..took a one quarter turn...That would not be it ..right?.or could be...its possible he forgot the one that I can not see??..location?
thing is.... it was still filling up... causing the bilge to go off every 10 to 15 minutes..even without the engine running..!
guy at the marina is new ,..so not really confident he did everything right..thing is..the leak is ... BIG.!...I agree it may not be the thuhulls..to much water..too fast..scared me man!Ran for the trailer!.All...between big storm fronts,in a hurry.. to get it out..of the water..unfortunetely the bilge emptied. Just as I was loading on the trailer...the way it goes for me lately..
Grahamu.I.will ask marina/restauraunt for a hose thursday..I think it may be something worse too..drive leak??from the shifting cable bellow?...or something..(looks O.K...if a bit stiff)..its just that last year..it floated fine,..in marina all summer.
After having a deer jump over the front hood of truck on the way up to marina ..almost crapped my shorts! last weekend..and the boat almost sinking ,..I am thinking of just calling it over..Marina guys will take all summer to get to the beast..to fix anything big...anyhow..boy is the better half giving me the business..what to do..??will try all your suggestions..thanks guys..
just trying to figure it all out.Check...The residual heat loop..right?
Two hoses laying below the loop are the ones that go to water heater
Thank you!
