Dinghy motor hp
skennelly
Member Posts: 2,196 ✭✭✭✭
What size motor for a 8' 3 person dinghy?
Would a 3.5 or 2.5 work for putting around the harbor?
Any recommendations on electric at a good price point?
There are a couple of Torqeedos at my marina but I just looked them up and $$$
I ran an electric start 1986 Yamaha 4 stroke for years. Never gave me a bit of problems but that 100 lbs sucked to lift
https://crateinc.com/history-tohatsu-outboards/
I had issues with the little Merc...I was really frustrated. It ran great initially and then all of a sudden started to run like crud. It would die and then dump fuel out of the carb indicating a stuck float or something like that. WTF...brand new outboard.
I took the engine home and ran it on a garbage can full of water and disassembled the carb. Turns out the float assembly has a rubber plug that covers one of the jets that popped out causing the carb to flood. Replaced the plug and back in business.
Crazy.
The motor instructions absolutely say you can store it laying down...there's even a sticker on the motor.
