Vacuflush - duckbills & bellows replace.
Post 1000 !
Gonna do some service on our Vacuflush system. S-series. Pump runs too frequently.
Duckbills, bellows & O-rings replacement.
Assume the best way is to remove the pump housing & motor & work on the unit on a bench???
Any suggestions from experience?
I'll double check the foot pedal O-rings as well.
My plan is to R&R the pump parts all together. Hasn't been done since new (2014).
Think best is to pull the entire pump housing out & deal with it out in the open. Not all buckled inside the boat.
I understand the Dometic bellows that were mfg'd after 2017 were made with a more durable material. Should be replaced regardless.
No issues at all. Used lots of synthetic grease.
Had to replace the bellows - too tight & too many bolts to loose if I repaired in place.
FYI: Dometic/SeaLand recommends replacing bellows to a newer version. Pumps prior to 2017 have issues with bellows failure. The revised new part has a grey pump arm. The orig equip that needs to be replaced - has a white pump arm.
Ray
2006 390
Previous 2000 340
Ray
2006 390
Previous 2000 340
I did the same as you and climbed in where the ice maker was.
I used Permatex synthetic grease where needed.
Everything operates much more quietly & pressure is excellent.
Have to really listen for the Vacuflush pump now.
Just don't eat peanuts....or at least chew them up very well. First 10 day trip on this boat 10 years ago, I learned where the duckbills were on a 95 degree day (I had no new ones at the time - I now carry two sets of 4 as spares - so I had to "clean" them and reuse for rest of trip). Did I say, the boat was new to me? Think about it. At least I'm married to a nurse and she always has those throwaway gloves.
Ray
2006 390
Previous 2000 340
