Smells gone! Big Orange Filter
jaubry
Member Posts: 125 ✭✭
Well, I installed the Big Orange filter the evening, and instantly the smells disapated to nothing. This really works.
I've gone as far as giving them away to my boating friends. The Admiral usually appreciates it the most. It's a primal male thing I guess.
thanks
C
A couple fittings and hose clamps and we are smell free. I'm interested to see how long it last.
I like the a/c carbon idea even better.
Mike
I use tie-wraps to secure it to the outlet hose (or any convieniently stable spot) just to keep it from flailing around if I'm getting pounded on a rough day.
Thanks DI! I will take a look for it next weekend when i am down at the boat.
So I made the run to HD during lunch. I spent $15 on parts and then went to Petco and purchased some activated carbon pellets, which was another $15 (enough for 3 fills). I decided to do 2" PVC, 16" long, as the barbs fit better into the threaded PVC plugs. Now to install it on the boat later this week. Picture below.
hmm. The picture doesn't seem to want to load.
I installed the Big Orange last month and one of the hoses, the one from the tank to BigOrange, the stink is still there, ugh! I truly believe it is the old hose though, the one going from the filter up and out of the hull. The old piece I removed stank so bad on its own we gagged, and I'd already thrown it out on the swim platform!
So I want to replace the old hose and am looking on how to do that, we've got a 270 and the prob is I'm 6'5", kinda hard to get back in there! I can't even get to where I can see the hose going out the the hull from under the hatch. You should've seen the acrobatics I had to do to replace the bilge and float, lol.
Any suggestions?
Named her "FAMILY THERAPY"
Two things:
1. Use new sanitation type hose (white) for the vent line. Old type tubes or the incorrect tube will let the small permeate.
2. Check the vent hose connection at the tank: mine was all jacked up. The fitting on the tank was 1/2"...the tubing was 5/8" and Rinker just used a worm clamp to smash it on to hold..but it did not seal. I ran new 1/2" tube to a barbed adapter to get to the 5/8" and then new 5/8" to the big orange and then to the vent.
Find a smaller friend who is capable and willing to work for cold beer to help.
