342 fuel system
Where is the anti-siphon mechanism in my 2005 342?
I had a fuel leak and need to have the mechanics check the fuel system....
The engines are Volvo 5.7 OSXi-DF.
Is there a solenoid valve or an old-fashioned ball-and-spring mechanism?
I had 10 gallons of gas removed from the stbd engine, and we are chasing the root of the problem.
"All things are ready if our minds be so"
-W.Shakespeare/Henry V Rinker 2005 342FV T5.7OSXi-DF/OceanX(DPS-B)
The fuel system is absolutely closed system, and the injectors are 'normally closed' mechanisms in themselves.. I'm willing to be the fuel pump seats, and if the boats equipped with a cool fuel system, that will do it too.. but, I'd like to know how the fuel can siphon through the filter/water separator... I'm all but certain a spin on filter/seperator is equipped with a diaphragm valve to disallow flow unless it's under pressure... It's not under pressure when the ignition is killed, because the injectors close north of the fuel filter/ cool fuel / water separator, and the pressure south of those devices will fall...
Pressure on the rail is where I'd start hunting.. it should bleed slowly once ignition is killed.. if it bleeds rapidly, a good nose will locate the trouble.. if it doesn't bleed slowly, I'd be looking at seals south- like a spin on gasket, or a bad fitting, or anywhere else the lines can rub... I'd also pressure test the tank.
Don't get me going on injectors.. :-)
I'll add this, though: if you're replacing one, you will be asking for issues.. replace them all, is my advice, and have them bench tested for uniform volume flow and spray characteristics at their rated pressure.. these engines can't sniff exhaust and adjust trim w/o an o2 sensor, which means the puter trims based on tables and temps... One cylinder could be running rich or lean, and you'll not know it until damage occurs.. even with a o2 sensor, it can only tell which bank (dual sensors), or overall a:f from both banks (single sensor)... You'll want them benched for uniformity.. even injectors off the line one behind the other will vary.. benching them groups them by 4's, 6's, or 8's, and gets you closer.. take a variance out of the possible issues, right?
Call up five o, and ask to speak with Bruce.. man knows his business.
Chebby does.. fomoco, too.. mopar doesn't always..
I'd be willing to put money on a ruptured line, as BD is indicating... especially if you've habitually used ethanol laced fuel- it is caustic to soft lines... a matter of fact, this is the only solution short of stainless lines:
and that stuff is pretty expensive..
if you have/had a deterioration of lines from the inside out, there is usually evidence in the filter or in the injector baskets in the form of tiny rubber crumbs... if you have a rupture in a feed line, you're not going to generate pressure as easily to feed the engines, and should have felt a shimmy and shake in the engine, at least at some point along the way. A leaking injector washing the cylinder would likely cause a misfire at least here and there, and it would certainly cause some more smoke/fumes at exhaust. the best way to tell, though, about a rich (or lean, for that matter) cylinder is to pull the plugs and compare them to a chart.
so... how does it run? rough? smooth? hard start?
Thursday I changed a spreader light, all looked good, the bilge pump emptied out some rain water from the previous few days, no smell of gas...
Friday afternoon, the smell of gas was noticed before entering the boat!...blowers on, shore power off, engine hatch up! Gas in the bilge!
Port engine was all good.
Starboard engine...gas drip on rear of port exhaust manifold...
Throttle body, fuel rail, fuel regulator, intake manifold,,all dry...
oil dipstick...completely covered in oil to the very handle!
oil cap: open, look and fresh clear gasoline in the stbd valve cover, PCV valve disconnected, gas in the port valve cover!
THE STBD ENGINE IS FULL OF GAS~! Twin Volvo Penta 5.7 OSXi-DF
An emergency cleanup was done and about 10 gallons of gas were hand-pumped out of the engine, followed by removal of the plugs and cleanup of gushes of gas from several, but not all of the cylinders...
There is no shortage of theories around the dock....What do you think?
Wow, that's odd. I think you would have had to have a series of problems for that to happen. I can't see fuel siphoning and filling your engine with gas...sounds more like the fuel pump was still on and leaking injector(s) at the same time. That's a lot of fuel to fill up a block...
I am not sure of the Volvo set up, but if the fuel pump is mechanical and the diaphram ruptured, that's a straight line for fuel to the crankcase.
Is the bottom of the tank above the engine or where the regulator is? That is what would have to happen to naturally flow...
Check your tank vents.. the only thing that makes any sense to me is if the tank built pressure due to heat and movement, and couldn't vent, creating positive pressure.... But ten gallons? That is freaking weird.. I dunno if it could build enough pressure to push ten gallons up the pickup tube, through the filter and past the regulator past a either a faulty injector or one that succumbed to pressure, and into the cylinders and crank case...
Two of those cylinders at least had open valves which could have overflowed through the intake runners into the valley and down into the crank case, and that is pretty much the only reason both the cylinders and crank case would be loaded...
How many cylinders had fuel loaded? If just one, okay, you bled your fuel system through a bad injector, and had the misfortune of that injector being atop a cylinder that had an open intake valve.. if two, same thing but the odds seriously decrease.. if all.. well.. that is just weird.. it's almost as of the fuel delivery process kept happening after ignition had ceased.. unless you had multiple things happen at once..
http://www.marinepartseurope.com/en/volvo-penta-explodedview-7744410-23-6572.aspx
take note of the replacement pump p/n... find a TSB that covered the new design.. if you have one prior to the redesign, you may have your explanation and a course of action.
friend, have fun with this... you've got 'em by the short hairs.. document document document...
http://seastriper.com/forums/showthread.php?t=8867&highlight=fuel+pump
you're going to have to register to see it... answer to random question is '****'... you'll see when you get there... :-)
this is something Al would have known about immediately if I hadn't P'd him O..
by the way- you learn something new everyday- the USCG doesn't allow gasoline fuel return lines.. it's considered 'under pressure'
Nice find Drew...It almost has to be an issue with the fuel pump..siphoning through filters, all the piping, fittings, etc. just too difficult.
re: anti-siphon valve.. I've got some fairly bad news for you.. If you bought your boat new, it's likely there.. if you bought it used, it's likely not.. they were problematic, so folks just ganked them.. they are just outside the tank, and amount to a check ball and spring T in the line... they liked to stick, so folks simply removed them to protect the pump..
anyway, all this is documented in that lengthy thread where I pointed you... by the way, Moby was a whale.. the four letters following Moby, which is also a short name for someone named Richard is the answer to the random question while registering at that site.. you'll have to register to see the thread... the bad word filter on this site wouldn't let me type it for you to see.
for what it's worth, here is why:
to siphon, the vacuum needs to be able to produce more pressure than the SURFACE tension of the source- the surface, not the weight of the source from the bottom- if it's going to draw from the BOTTOM of the source, it needs straight up PRESSURE to do so...
the tanks basket is on top.. the feed tube drops into the tank, from the basket, and pulls from the lowest point.. if it pulled from the tank from a floor mounted sump fitting, then it could easily have filled your engine if the engine is lower than the tank, but as in gravity fed and relying on the pressure of the source itself...
in order for siphon to happen, it has to have a vacuum produce enough pressure to break the surface tension of the source and maintain it by creating a vacuum when it falls out the other side of the pipe/hose... the falling fluid creating the vacuum behind it HAS to be maintained.... there ain't no way fuel naturally fell through a filter/separator, two stages of pump, and into the engine.. ain't gonna happen.
your fuel was pumped into your engine... ten gallons? valve covers full? crank case filled to the dip stick top? ... that isn't the work of one open/faulted injector, or even four... that is the work of something pumping.
do you have someone who doesn't like you afoot? seriously.. the only other thing that makes sense is pressure in the tank being great enough to push through- and only due to obstructed vents and some pretty serious heat...
I'll be really interested in seeing how this is diagnosed... it doesn't make sense.
Siphon, vacuum, surface tension, pressure, nonsense.....all you need is a continuous communication of vessels filled with the fuel and one level higher than the other, and by the law of communicating vessels, the levels will try to be equal to each other....if there is no obstruction, or even if there is a little...as long as there can be flow from the higher level vessel to the other, fuel will flow!
That's why ABYC and USCG reg require an antisiphon valve...in case a hose leaks or the engine itself leaks....
I am going to test each tank with a hose and a bottle to see at what level the tanks are filled relative to the engines....the experiment will work only if the anti-siphon mechanism is indeed stuck OPEN.
so... continuous vessel... after this very unlikely roller coaster ride ten gallons of fuel took from your tank to your starboard engine, rising up of it's own accord and building enough vacuum behind it to continue the process, how do you figure the engine was filled to the valve covers? is that source not above the suspected faulty injector atop the cylinder that just so happens to be in the intake stroke?
here is how you solve your problem- not kidding... collect surveillance tapes from the marina.. what you suggest is dang near impossible without pressure either in front or behind the fuel.
best of luck finding out what happened.
That item #25 looks like it pulls vacuum signal from the intake manifold... Pulls it open when engine turns over.. still.. that is one helluvar roller coaster ride for fuel under only siphon powered motion... How much lower than the tanks is that dang engine?
