Cleaning up a little boat use I hope!
rasbury
Member Posts: 8,688 ✭✭✭✭✭
Finally got the boat home , cleaning up a bit and looking at the projects that still need to get complete!
Couple areas I could use a little input on our 06/270.
I keep a moring cover on it trailered, fresh water boating is our wheel house.
Recently replaced all the helm and lounge area interior/carpet.
I've had the boat 8 or so years and the front deck has really taken a beating from the sun. Just can't keep any kind of finish to last very long. It gets pollen all over it...mold starts and it's tuff to clean (using deck cleaner non skid stuff) and I know I have to keep up with something as I'm guessing that's just not good for the hull..and ditto for the swim platform...I swear I'm thinking of painting both those surfaces, is that a reasonable option?
Speakers- still have the factory original everything and if that worked, I would not have a problem. It has the controls at the helm and the swim platform (never worked), it has a separate 6 disc, over the TV area there is a big amp of some sort. Couple of the speakers have blue crap running out if they get wet and one by the map pocket I swear is a source for a cabin leak. Will they leak through that speaker material and at the least with the blue crap, time to just update? Still use the amp ? All the speakers seem to sound OK but if that one is leaking...
I have not addressed a trim issue. .it "works" but afraid it's going to strand me. 100 % electrical and will do some research.
Thanks for any input! Always pick up the tips here...
Mold Armor 32 oz. Mold and Mildew Killer and Quick Stain Remover FG502 - The Home Depot
I'm going to try and buff the color on the hull and throw some wax on the side, the covered interior looks pretty good.
So, the speakers are Sony xsmp62 and looks like a common marine speaker...which I know nothing about..specs say:
6 1/2" 140W, 4 OHM. Woofer with a 2" tweeter.
I don't need to be the guy that pulls up that the radio causes its own wake..what is important to look for as replacement? I see others that don't say having the tweeters...some are 280 W, is higher number ok? 4 OHM, does that need to match up? Dual cones? I pulled the one speaker and poured water and it ran right through...the seal of the speaker material against the metal frame is not good and must be the cause of my mid ship cabin leak- the other 3 if the leaked it would do into the bilge- the one by the map pocket would head right in there...
