ECM PROBLEM 340FV
downunder
Member Posts: 29 ✭✭
have an ecm problem on one engine. engine will not rev over 3400 when under load. have swapped ecm's on the engines and problem follows.
Its like a rev limiter action where the engine just momentarily stops and you can see the tacho bouncing. once you drop the revs to 3400 all good etc
So i need to replace the ecm, now looks like no longer available from mercruiser!!!
the details on the ecm and engines as follows
Original delphi part # is 16236999 [see pic attached] am also told mercruiser part # 861926T3. This supersedes to 892798A01 kit and when i google it
This product is no longer available!!!!!!!!!!!
My existing engines are the 350 merc with efi [throttle body] rated at 260 hp
Engine details 2001 mercruiser 5.7 tbi 260 hp Eng serial # OMO15253 & OMO15252
would anyone have a used one they want to sell or know where i could get a new one or a used one?
really appreciate your help on this as its starting to bug me,
I am coming over next week for a trade show in Las Vegas so i will be on your side of the world,
regards john
"festina lente" - 2001 340 FV
https://www.ebay.com/itm/185613516618?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=7HErPoNoQMy&sssrc=2349624&ssuid=jb9VSTJCQVS&var=&widget_ver=artemis&media=COPY
updated the link, they cleared the shopping cart link I posted earlier.
https://obd2allinone.com/555scan.asp
I didn't know this: When the ECM throws a fault code, it saves a "freeze frame" of engine data at that moment (RPM, voltage, and everything else the ECM can see). That would be really useful in troubleshooting.
