New Galley Faucet
2»
  • aero3113aero3113 Member Posts: 10,106 ✭✭✭✭✭
    Agree!! This is how I found mine when I first bought the boat!!
  • mattiemattie Member Posts: 1,323 ✭✭✭✭
    1.5 seasons on mine & it was gross. Not even that much use. (which may contribute to it)
  • J3ffJ3ff Member Posts: 4,245 ✭✭✭✭✭
    Well, I guess this explains what happened to the faucet! Will make it a priority to get a screen for it. Have NEVER opened this thing, so the previous owner must have removed it. Great.
    As a follow up to replacing the really good faucet from the original post:
    - I purchased this one for right around 40 bucks on amazon.
    https://www.amazon.com/dp/B075294KMD?psc=1&ref=ppx_yo2ov_dt_b_product_details
    It did NOT come with the adapters in the listing (+12 bucks, I did write the company telling them they owe me for it, figured they owe me that for hitting 2 different hardware stores and about an hour on google).
    The adapter needed is this part, both male ends:
    in order to fit into the stock lines:
    Either way the end result is awesome. For a while the thought of needing a new pump or higher pressure pump was on my mind. However that thought is gone now. Plenty of water flow and nice pressure!
    10 dollar sink strainer from amazon going in next weekend.
    Got a new strainer in.. now need a new sink! (stains/scratches)..
    edited November 2022
    Try a product called Bar Keepers Friend. Won't remove scratches obviously but will shine up that stainless steel like new. If you do manage to find a sink it ain't gonna be cheap.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,986 mod
    I agree Bar Keepers friend and or flitz.  I usually use bar keepers friend then follow up with flitz.  It is absolutely amazing how much it will shine!
  • earl1z19earl1z19 Member Posts: 382 ✭✭✭
    Not sure what a new sink would cost but with a bit of effort that sink could shine like new. Rotational buffer + Buffmagic and about 30 minutes
    Was joking :) but thank you, I have all three of the suggested items ready to go. Will give it a shot next weekend.
  • MH342MH342 Member Posts: 73 ✭✭
    Nice work!  Can you post a link or details on the strainer?  Looks like a drop in replacement. Mine is also corroding.
    https://www.amazon.com/dp/B000DZF8DQ?psc=1&ref=ppx_yo2ov_dt_b_product_details
    You need something called plumbers putty as well, to put around the bottom of the sink to where it contacts the housing of the drain, the wide part.
  • echandler1971echandler1971 Member Posts: 253 ✭✭✭
    I did my 360 today. Note that in my case, the old faucet was male 5/8” fittings and there were female connectors on fhe Pex. I had to remove the connectors and put straight 3/8” shutoffs on the Pex. I used Sharkbites due to the cut off pipes being blind to me behind the back of the sink cabinet back wall.
    Dan of Steel
    '05 Rinker 360 Fiesta Vee
