Kohler 5KW EC 72 error code. Where is the Starter Relay located?
Hey Guys,
I have been running the generator with no problems until last wee. The genset would run and then stop suddenly and show EC72. I think is the power relay. Does anyone know where is it located and how to get to it?
Thanks in advanced.
You actually have to use it to have a problem with it!
I poked around for a while looking for loose wires, found none. Luckily, this is the only night we'll be on the hook for this trip.
When the genny died, I gave all of the fuses a visible inspection, and they all looked fine. Today I checked each one with a multi-meter. F6 looked normal, but failed continuity. I replaced it and -- problem gone.
Read this thread, it talks about the EC72 code.
https://rinkerboats.vanillacommunities.com/discussion/7899/generator-acting-flakey-diy-instructions-to-replace-the-fuse-holders
