342 Solar
alex8q4
Member Posts: 66 ✭✭
Hi all,
I’m killing time by planning the install of my new solar panels on my 342.
This project will require me to run a couple of cables through the arch, down the port side, and into the engine bay.
Can anyone with a similar boat tell me the approximate / ball park length of cable I’ll need to get from the centre of the arch to the forward wall in the engine bay?
2006 342FV - Ontario
Word of caution - the 350 does not have an cut-out at the base of the arch on the port side for wiring to pass through. Only the starboard side had a cut-out and all the OEM wiring ran through the starboard side. As a result, I went with 30' of cable to go down the starboard leg of the arch and across the firewall to the port side. Got the cable on Amazon for about $60 including the MC4 connectors.
Also remember to ensure that the solar controller is ignition protected. The Victron one I have is not so I located it in the cabinet below the cockpit sink.
Cheers
Truth. After I ran a new radar and good speaker cables, my starboard side has no more room for anything with big connectors. I wonder if the arch base on the port side has openings. You could easily drill the fiberglass if that's the only obstruction.
Edit: found this thread, check it out. https://rinkerboats.vanillacommunities.com/discussion/8505/fixed-not-fixed-fixed-leak-where-windshield-frame-attaches-to-hardtop-arch
The moral of the story is that we didn’t learn to not ignore the leak, but that we can’t ignore the leak!
Hopefully, one day someone looking to do the same will find this helpful.
https://marinesolar.com/sunpower-semi-flex-kits
A word of caution. The solar controller is not rated as ignition protected. You might want to relocate it outside of the bilge.
Victron offers a ton of products catering to the RV/marine market including many that are ignition protected. There must be a good reason why the solar controllers are not rated as such.
That being said, insurance companies would not approve of a non ignition protected device in a confined space with gasoline.
