Replacement trim cylinders
Well, I sure wish when I pulled my transom asy I would just replaced it all, I have one trim cylinders that is pushing parts out of the end of it and obviously where my water intrusion came from.
I have not really looked at price for new and probably going to find a used one or replace them both. With what is going on with the bad one I'm not sure it can be serviced so don't want to invest the time and money to find out as they look pretty cheap and have not heard of one going bad except for heavy use...
How do I know what will fit mine as I'm sure I can't shop by part number?
The transom assembly is the same for Bravo I/II/III. The trim ram part number is cast into the tube (circled in the image below). Looks like 98703/98704 and 98718/98719 are available as per the EPC. Shouldn't be hard to verify what you have now and replace with same.
https://www.sterndrive.cc/product/Fits-Bravo-Hose-Hardware-Kit-AL.html
I'm going to disconnect the lines and push out and flush as much bad fluid out as I can and figure out how to bleed them.
Update- I'm reading that compression fittings are not reusable. So, I guess I have to replace the 4 lines from the little manifold. I read also that once tightened hand tight it should not require more than one revolution to seat the fitting and complete the seal. I would say bad design but I guess for connections not subject to taking apart very often it's cost effective. Just disappointing I could not launch this week and going on vacation. When I pulled the transom asy apart I know I replaced the two main lines from the pump to the manifold- I don't recall replacing those for sure...if I didn't then I was lucky. I also read it's a good idea to use perfect seal on the threads- not to seal it but so you can get it apart one day and not go through what I did to get the one line off. I guess I will have the new lines waiting for me when I get back from vacation.
You should be able to hand thread the fitting until it's snug then gently snug it the rest of the way. Similar to how you'd tighten a brake or clutch master cylinder hose fitting. It's a compression fitting, not a lug nut. It's very very easy to cross thread these fittings when the housing is such soft metal. If you can't hand thread them don't be tempted to use a wrench to force it the rest of the way on. This is how you screw up a cylinder....I only know this from hands on experience...and I've screwed up more than one simply because I was rushing.
