Installing and air conditioner
Bayrunner
Member Posts: 177 ✭✭✭
I need to replace my air conditioner with a 16000 BTU EnviroComfort Air Conditioner Reverse-Cycle Retrofit Kit. Is this something that I can install. I an engineer and I don't think I would have a problem but thought I reach out to some of you to see if it's doable.
Bayrunner -- FV312 - Simple Pleasure
I put in a 9000 BTU unit only to remove it and install a 12k the next season.
First install took a whole day, the second took a couple hours.
The wiring wasn't overly complicated. Running the duct work and water hoses was the most time consuming part. Wiring consists of running power to a new breaker and then to your ac control, then ac power from the control to your water pump.
Pluming goes from thru Hull with shut off valve to strainer to bleeder valve to ac. Then ac to discharge thru Hull.
I ran my bleeder line/ac condensation drain and shower drain all to a collection box with an independent bilge. I like a dry bilge, it's not clean like @aero3113 but it is dry.
Most of the install was basic hand tools, impact driver, drill. Hole saw bits if you have to run ducts/vents, thru hulls
I was up near Seneca last year, staying at Bowley's quarters. It was our first time on middle river (hard to believe, 24 years of boating and never been in that area). The admiral & I like to do a lot of walking and did most of that peninsula. Definitely a nice area. We happened to be there the day the famous landmark came down. That was rather impressive!
DOMETIC
I plan on replace it once I get the leak in the starboard sterndrive fix. Oil line from the reservoir to the out drive is leaking. The problem is Porters Marina is looking to hire technicians but no one wants to work on boats. So I feel this is going to be a painfully slow fix. If I knew someone who could fix this I hire him to fix mine.
Fits well. Came with new display and manual suggested the “legacy” one was compatible but I had to plug the new in to get it running. Calling them tomorrow to check.
