Water Heater Replacement 2003 270
Never can have a problem free year I guess... I finally got around to flushing out my fresh water tank yesterday and I found that I didn't have any water pressure at the taps. Thinking it was my water pump, I looked into my engine compartment and heard water running. Looking to the port side, I saw a bunch of pink water pouring from the bottom of my water heater.
Oh well, it was acting up last year. I can think of worse problems to have.
Anyone know of any good deals on a replacement before I start digging?
"Mosi on Dahn" 2003 Fiesta Vee 270
https://www.hodgesmarine.com/kuu11811-kuuma-6-gallon-water-heater-120v-front-heat-ex.html
It was the best price I found at $326.40
My only gripe, which you gasser guys can't do but us diesel guys can get away, with is the wiring. My battery chargers use outdoor rated plugs and outlets. I really wish I had done the same for the water heater. This way when it's empty for the winter I don't accidentally hit the breaker and burn it up as I could unplug it while I'm under the hatch. As of now I have it hard wired inside the junction box by way of factory set up. Come winter I may replace it with a 110 outlet cover.
The new heater was about a 1/2 inch wider than the old one. I had to remove one of my water tank brackets to slide the new one in.
