Generator - Kohlor 5E
apdcopapdcop Member Posts: 23 ✭
Just curious if anyone would know what to do for this problem... the other day I went to start the generator from down in the cabin area and when pushed the rocker switch it did not do anything.  (the battery is fine)  So I went down the start it at the control box that is on the generator it self.  The unit started fine.
A few days latter I tried again in the cabin and the same.  So next I go to the generator control box but this time it also does not work at the rocker switch.
Could I have a bad rocker switch?  (I just don't think that I would two bad rocker switches)
Thanks in advance
Patrick Magrum
