Installing and air conditioner
2»
    @ian It looks like the pic is in this topic...AC hose — Rinker Boat Company (vanillacommunities.com)
  • IanIan Member Posts: 3,064 ✭✭✭✭✭
    @Dream_Inn that did the trick. I tried the flow back through the outlet and no good so I tried loosening a couple of screws on the pump, nothing. But loosening the 3rd and it started to burp and bubble out pink and then no more air. Tightened them up, kicked in the AC and I heard spurts, went to go look and after a few more spurts pushing out the air, a nice stream as expected. Great tip, thanks.
    Hope it works well!
    Finally primed the pump and yes, it is working very well. Much quieter so the Admiral should be able to sleep now.
    Great to hear @Ian !
    Ian said:
    Hope it works well!
    And she came down today and loved how quiet it is. All I needed to do was change the low speed fan minimum to 30% from default 55%.
    That’s awesome! Glad it worked out so well!
    edited July 2023
    Ian said:
    Ian said:
    Straight swap but sure, I’ll take a few.
    Fits well. Came with new display and manual suggested the “legacy” one was compatible but I had to plug the new in to get it running. Calling them tomorrow to check.
    Do you have to upgrade de 110 electrical cable to a bigger size plus the breaker at the panel for the new 16000 a/c?. I am going to replace mind, but I don't want to create more work for myself going from 12 to 16 new a/c. thx
    Nope, the same is fine. Current draw on the new bigger unit is no more than the old.
    Appreciate.
