Offsetting Excess Weight/Trouble Planing
YYZRC
With the new dinghy (700lbs) and platform extension (200lbs) and no bottom paint, my old girl really struggles to get up on plane. I’m looking for ideas (short of dropping in 8.2s) that will help. I already have the 4x4 props.
I will give in and bottom paint the boat this winter - the water is 2 degrees warmer this year than past years and the growth is insane.
As a starting point, I am considering larger trim tabs with the hope of extending the running surface somewhat. I will also try swapping the cucumbers on the drives to get a bit more negative trim.
Any ideas/recommendations?
Like the Dr who nemesis mentions, put a few passengers in your bow.
And since it's not my money some high output 502 motors and new XR B3 drives sound like the ticket lol.
https://defender.com/en_us/bennett-drop-fin-set-df12
will give you the performance of tabs 6” wider than the tabs you put them on
Thinking of adding
You're adding 50% more tab area, plus drop fins. You'll need at least 50% more force from the actuators. Are they strong enough?
Can you first try it without the drop fins, and see if it solves the problem? Only add the drop fins if you need them?
I read a number of great posts by a guy who went by “Tabman” on several forums. He worked for Bennett and made recommendations to improve tab performance. His recommendations were always bigger tabs first and then drop fins second. All the tab sizing charts recommend 36” x 9” or 36” x 12” tabs for a 35’+ boat. Double what Rinker installed.
I've seen posts by Tabman -- seems to know his stuff.
